One of the first things I will do when (if) I get my 2016 Spyder RT-S is install the GPS mount. I had a couple questions I was trying to get answered before I definitely decided on using this kit. Step 24 says to “Remove cap from ignition switch cover”. Later, step 12 says to “Mount the GPS support [P2] to the ignition switch cover”. How does the ignition switch cover attach to the GPS support? And what covers up the hole (that the GPS cables are fed thru) that is exposed when the ignition switch cover is removed? In the instructions they have you remove a lot of panels on the left side of the bike. From my understanding the GPS cables will connect to the bike on the right side. Why are the left panels removed? If anyone has any other thoughts I would appreciate the feedback.
Data
Data
