MakoShark2
I would like to check my VIN, but is there a link for European Spyders as well?
Best regards,
Allan
Yep... I'll second that... Where all the fellows of the Old Continent can check their VIN number?
Best regards,
Allan
I drove it to a dealer and found that it was closed due to Presidents day. I did however check the torque before I left and it was way under the 92 pounds. I torqued it to 92 and went. It should be OK till the next chance I get to drive it down there.
How many miles???
How many miles???
Just got back from getting my Spyder sprocket replaced. They gave me the old sprocket. It was pretty worn and rusty. He said the part number is now different. That means they finally have upgraded the sprocket.
I discovered the red dust on my 2015 F-3 sport after 13,000 miles two weeks ago. I ordered the pulley sprocket, bolt, washer, off of cheap cycle parts.com...ordered the loc-tite spline grease from amazon. My mechanc installed it and torqued it at 92 ft. pounds...I also installed a new kumho rear tire...as a safety precaution im going to replace the pulley, bolt and washer every two years...and also inspect the pulley at every oil change (every 5000 miles). its not expensive to replace it..as long as you catch it before it fails. This is the best way to do it...my mechanic agreed.
Sorry but that is not correct. Part number 705502134 is still current for all F3 2015 to 2019 and is the same part that was installed on my very early 2015 F3 (unit number 103). There is no upgraded sprocket nor is there any problem with the sprocket. Its the installation of the sprocket that is causing the issues.
A local rider that required needing his front pulley replaced informed me that Can Am / BRP is not recommending Loctite in the TST and provided a copy of that info. Seems some have used Loctite, ours was lubed when assembled new and has no wear. Just sharing info, not saying what is correct or better.
I am just relaying what they said. I asked him what improvements and he did not know. I just assume that the only improvement they could make was the type of steel but I dont know. I do trust this particular dealers service and Chad who does the work. I could have gone to my local dealer in Greenville but do not trust them. I had to arrange transportation from and to Richardson in some pretty nasty weather in the middle of rush hour in Dallas.
What I will do is go take a pic of the new part and post it to compare the numbers stamped on the outside.
I did not use the loctite 648 sealant...I used the BRP recommended moly lube spline paste so it will be easier to remove if/when it needs to replaced in the future...
He did say that he used Loctite 648 on the shaft and bolt.
Well, the bolt will not backoff or fall out...
FWIW, most timeswhen using Loctite products with a high strength rating, you must use a lot of heat to soften the bond. I would believe 648 on threads is a very strong bond and myself would be cautious when removing that bolt, fearing it will snap off inside the shaft, but maybe not.
The BRP recommended stuff apears Zinc based, not moly based.
https://www.norelem.com/xs_db/DOKUMENT_DB/www/NORELEM/Sicherheitsdatenblaetter/97901-060_Si_EN.pdf
