...... it sounds like the proper thing to do to prevent failure is at each oil change remove the bolt and sprocket to inspect, clean, and reapply spline lube with a fresh bolt. Guess I’ll do all this at her next oil change.....
I dunno, lugnut! :dontknow: Bearing in mind that you're meant to change the oil once a year
or at the scheduled milage,
whichever comes first, and that the bolt used to hold the sprockets on is meant to be a single use bolt, replaced every time you take the sprocket off, plus the fact that removing/replacing a splined sprocket on/off a splined shaft
WILL wear whichever is made of the softer metal; I'd think that changing the bolt & checking the sprocket every year
or sooner (as per milage/oil change schedule) would probably be a pretty self fulfilling excercise..... Do it often enough and you
WILL wear the sprocket out sooner than it would if you just inspected the sprocket without removal! :shocked:
I've seen it before, sometimes on quite important and expensive pieces of kit.... Over-servicing can be just as damaging if not more so than under-servicing! So please, don't go needlessly pulling the sprocket off! :lecturef_smilie:
Sure, check for the red dust; check the torque on the bolt if you must (but that'll probably hurt the locktite!); maybe even take the belt off & check the sprocket for looseness on the shaft; heck, you might even take the bolt and sprocket off now (just the once!) to inspect, clean, and reapply spline lube with a fresh bolt, then leave it as is
at least until there's
some indication that it needs attention again! But whatever you do, don't just remove the bolt &/or sprocket every oil change just cos you've read all the doom and gloom reports here! Forums are where people come to resolve problems &/or vent about them, so the number of reports here likely doesn't reflect the reality of all the other Spyders out there with no sprocket issues at all! :shocked: Besides, doing that 'every oil change' thing would almost certainly cost you a
LOT more than is really warranted, and it'd very likely create more bolt/spline/sprocket issues than it'd ever resolve! :gaah:
Check & inspect in situ, sure, but only remove & replace as & when necessary! :lecturef_smilie:
Cheers! :cheers:
