Peteoz
Well-known member
Why are you using 2 different Krickets- Pictures and explanation Please. If you are using the Standard Kricket Ron sells and we All use you are not going to vary 100 Pounds from JUST an inch off the ground to ON the ground and If its 180 on the ground you have not taken the New standards Seriously? Happy New Year!!!
Sarge, re the gauges, there are two Krikit guages you can buy. One measures from 0-150lbs, and another measures from 100-300lbs. That is most likely why RR needs two different guages.
