PMK
243 Loctite should be the grade for use in oil. Ensure the threads are clean before using. I typically clean them with CRC Halogenated (Red Can) brake cleaner.
Where is the application of 648? I just pulled it up and it is Green cylindrical retaining compound. This one could be important if they are making a clearance 0/0 fit after torquing. Possibly a gear on a shaft or to prevent a bearing from spinning in the cases. Per Loctite it is a higher temp rated.
As Drew mentioned, Yamabond and 3 Bond work well to seal case seams if the BRP stuff is not available.
Regarding moly lubes, not sure where the application is. It may be a break in lube for initial running in.
All the best with it.
PK
PK
