So if my front brakes are constantly screeching, would I benefit from a brake fluid replacement job? 2021 RTL with about 5500 miles.
Brake pads would be my guess over fluid problems.
So when your pressure bleeding your system, does it not push fresh fluid thru the ABS?
I work on friends' bikes as a side hussle to my main job. Since I try to be fair, I tell my friends to find out what a dealer would charge for any given service and I'll do it for half. This person called a local dealer and was told it was a 5 hour job and would cost $700. I told her that was BS and I'd do it for $175. An independent motorcycle shop told her (without using BUDS) that it would be $175-200, plus $19.99 for DOT 4 fluid. Really? A quart of DOT 4 at Wally World is less than $8. And yes, I'm 1/2 hour south of you.
Changing to DOT 5 fluid would be easy. Changing all the rubber components to suit silicone fluid wouldn't be, as they haven't been made for a Spyder.
Just on the subject of cocktails I wonder how effective Buds is at clearing the bar so one could switch over to silicone fluid and avoid the hangovers associated with the old dot 4 juice.
...... If that fluid happens to be water, it can easily turn to steam, meaning that you basically will NOT have any braking power
Yes, the actual changeover would be relatively easy, but be aware that DOT5 brings its own problems.
As noted several times in this discussion alone, moisture that finds its way into a DOT3 or DOT4 system will eventually contaminate the entire system. DOT5 fluid does not absorb moisture, so it merely collects at the lowest point. That 'lowest point' might happen to be a caliper, which will be the hottest point on a long, downhill section of road. Using the brakes heats the pads, which then transfer the heat to the brake pistons and calipers, then the fluid. If that fluid happens to be water, it can easily turn to steam, meaning that you basically will NOT have any braking power.
Good info to know.What next for us.................... magnetics???
With that being said, I have been told that the fluid is replaced on a police vehicle after it has been involved in a prolonged high speed pursuit.
Here's the latest one I've done. This is from a 2021 F3L with 17k miles that is almost exactly 2 years old.
I'm seeing discoloration but not necessarily contamination. Is that right?
The 'discoloration' IS contamination! :lecturef_smilie:
It's all the moisture/water absorbed into the brake fluid that's making it change colour. The darker the colour, the thicker the fluid; the more moisture/contamination present.... :shocked:
