That is one of the things that got me wondering. In my (simple) mind, oil is there or it's not. I understand the oil pump moving it through the engine while it's running, but when you stop, it's going to collect <somewhere>. What moves it from there to wherever it ends up -- while the engine is OFF? :dontknow:
On a 'wet sump' engine (like that in most cars/trucks) there's generally plenty of room underneath the engine block for a 'sump' to collect a dirty great puddle of oil and hold it there ready for use, so that whenever the engine is running, while some components might be lubricated by splashing around in that puddle of oil, for the rest, the engine lubrication system sucks up and pumps the oil out of the sump up to wherever it's needed; and then this simple & cheap system lets gravity do most of the 'return the oil to the sump' work; where the oil pools & cools a little before being picked up again & filtered, maybe cooled a bit more, and then gets pumped back up to do its lubrication thing wherever it's needed once again..... So because the pump is always collecting oil from that puddle and pushing said oil up towards the top of the engine whenever the engine's running and then the oil has to drain back down to the sump under gravity, you need to wait about 30 seconds to a minute or so after shutting the engine down for all the oil to drain down out of the top of the engine, so that most of the oil has fallen back into the sump before you take your dip stick reading so you can get an accurate indication of the oil level. Easy enough to understand and something most of us are fairly used to doing, right?! Oil gets pumped up, oil falls back down under gravity. :thumbup:
But on a 'Dry Sump' engine (like that in our Spyders & in many other performance engines subjected to 'high G manoeuvres....&/or in engines that don't have very much room for that dirty great puddle of a sump underneath them!) whenever the engine is running there is still an engine lubrication system that pumps oil to wherever it's needed to do it's lubrication thing, but instead of relying on
gravity to do the oil return task (because gravity can be overcome by sufficient levels of those high 'G' forces experienced during performance manoeuvring) there are a number of 'scavenge pumps' that pick up the 'used' oil from a number of 'post high pressure delivery' pooling points, and these scavenge pumps actually
PUMP the oil back into (for want of a better descriptive term) the 'sump', only in this 'dry sump' engine's case, it's not a 'dirty great puddle at the bottom of the engine', it's a (generally somewhat smaller) holding tank off to one side or end of the engine somewhere! The oil still goes on its way via filtration & cooling systems somewhere in that loop, prior to its re-distribution under pressure to wherever it's needed; but the critical difference for us to note is that once its been delivered and 'used' wherever it's needed, the oil is then returned to that holding tank off to one side under pressure! The correct oil level in that holding tank equates to the correct oil level in a 'wet sump' engine just like the sump found on most cars, except because it's not 'a puddle at the bottom of the engine', that level will only remain 'correct' for a (shortish?) while after the engine shuts down and before all the pumps stop moving and losing pressure and the oil in the system starts to 'fall' its way back from wherever it is to pool in the last one of those 'post high pressure delivery' pooling points that it got sucked out of; and to some extent, because it's now only subject to gravity, it will also work its way down into the nether regions of the engine too..... (altho there's not really a 'sump' down there, there usually
IS one of those small 'pooling points'.
But for our purposes, it's fairly straight-forward - on our 'dry sump' engines, because the oil gets pumped up
AND it gets pumped back into a tank that's
NOT underneath the engine, if you wait too long to check the oil level in the holding tank after shutting the engine down, that 'holding tank' will have started to drain/empty (simply cos gravity comes into play again once there's no pressure &/or working pumps topping it up all the time anymore!) and your reading taken after that short 'correct level' window will be incorrect - hence the need to check your oil level during that 'still full immediately after engine shut down' period!! Make sense?!? :dontknow:
There's actually a few other things involved here too, not the least of which being the way oil volume expands when it gets hotter, up to a point; and how the 'holding tank' needs to be where it is in order to reduce the effect of gravity on
IT enough during operation that there's always going to be oil available for the delivery pump/s to collect & distribute oil when & where its needed; and a bunch more besides - but it's largely the 'high performance' & low profile nature of our Spyder engines that warrant this 'dry sump' lubrication system, and all 'dry sump' lubrication systems have a slightly different oil level checking method to that used on your car in order to correctly check that you've got enough oil in their holding tanks to do the necessary for & in your engine as & when needed. :lecturef_smilie:
Simples really! :thumbup:
