Lew L
Well-known member
Fixed a broken side panel mounting point.
Getting ready for the Run-a-Mucca rally.
See you soon with all the other BattleBorn members.
Removed all this from my trunk latch area.
I have purchased many windshields from 7Jurock and always get a good product and good service at a good price. I currently have two of theirs; a 17" and an 18" extra wide. Never paid more than $170 shipped.Last week new windshield from 7jurock 25" , Fantastic service from these folks .
Not if the oil is operating temperature hot.The oil change is easy, but a slow process, as it takes forever for it to drain.
Well then mine is different because I just got back from an hour long ride. First thing I did was take out the dip stick, then loosen oil filter lid, and then removed drain plug. It dripped pretty good for almost 20 minutes. So in my mind that is a slow process.
Last week new windshield from 7jurock 25" , Fantastic service from these folks . This week new backrest from SmoothSpyder .View attachment 190258View attachment 190259View attachment 190260
It was hanging loose off to the side so it was not hindering the draining.Not really trying to teach anyone to suck eggs.... but did you take the oil filler cap right off? :dontknow:
Can't stand beer, but even if I did not that early in the day. LOLIf you don't do that, there won't be much if any air getting into the top of the engine, so the oil hasta sloooowly gurgle it's way out of the drain hole &/or filter cap/s, letting gulps of air bubble back up thru the drain plug & draining oil to reach the top of the engine & equalise the pressure as it sloooowly drains out.... By opening the oil filler cap (where you normally add oil), you let that air get in easily & quickly, so the oil should drain out the bottom a lot easier & quicker!hyea:
And you don't really hafta wait until it completely stops dripping oil, just let it stop running out & then wait for the drips to slow a little. If you're draining stirred up & warm oil, anything left in the engine once the flow slows to 'just drips' is going to be pretty tiny and of no real consequence! So you can safely put the plugs back in, new filters & their caps back on, and start re-filling with oil once the 'old oil' has stopped running out & what's left in the way of drips escaping has started to slow. :thumbup:
There again, if you've raised the Spyder/Ryker, secured it, removed the necessary tupperware & under-body trays, then opened the filler cap, pulled the drain plugs, let the bulk of the oil drain, and finally loosened the filter covers, surely it's about time for a brew??So go have one,
then when you come back, more than enough oil will have drained out so that you can swap out the filters, finish the job, & re-fill with oil worry free! Don't forget that if you are doing this yourself, then unlike the poor tech who hasta get thru so many oil changes a day or lose his job, YOU aren't on the clock, so relax a bit, take your time; it's meant to be therapeutic & satisfying, maybe even calming and enjoyable, this 'doing your own servicing thing'! So enjoy it, take your time, and then get out there and...... yep, you know what's coming...
When I ordered a custom windshield from 7Jurock, made to my specs, that is wider than the stock mounting brackets, I knew that they provide no hardware. So I asked them to drill holes where the mounting screws go. I installed it placing spacers between the w/s and the bracket. Looks clean, works great. I never did care for those dorky looking black aftermarket brackets.I went to the site for 7jurock 25. It says no mounting hard ware would be sent. How did you mount it? I have a 2019 F3s
