condorflysu
2014 RT's
Does anyone with 2014 RT's have gas fume smells?
The fumes from the tank have to go through the rollover valve. There is no other breather hose. Only the one connected to the valve. So the fuel level just has to rise to valve, not the top of the tank.
Simply put there is either too much heat caught up inside the tupperware (toasting the gas tank much like my right foot) or not enough air flow to remove it.... or both!
Once I pass my 1st dealer service and document my own dissatisfactions, then I'll open this beast up and get to work. With pics :thumbup:
Good synopsis. As one that has been through this and tried to improve on the problem, I look forward to what you come up with. The more that work on this the closer we will get to 'THE' solution. Mine is better than when BRP built it, but not solved.
I got my 2012 Spyder RTS earlier this week and today about an hour after getting home, my wife says "Do you smell gas"? I immediately when to the downstairs garage and the very strong smell of gasoline hit me right away. The Spyder had been sitting for about an hour after my 10mi ride home.
When I bought the unit I checked the gas cap to make sure it matched the one shown in their recall PDF here http://www.spyder.brp.com/DownloadFile.ashx?fileID=f72284b2-d9a5-47f9-8d40-a22900b772fa so I think I have the proper gas cap.
Anyone have any ideas?
Sorry but one more person who THINKS they have a bike that is somehow different from every other RT that has this same DESIGN DEFECT just because they have not smelled gas, is not helping. Your spyder is designed the same in this regard as all other RTs up through and including 2013. The 14s are completely different. Just because you have not smelled it just means that you have not ridden in the same set of circumstances that I and others have or that your are less sensitive to the smell of gasoline. If I rode your bike here in Houston on my normal commute to work and back, IT WOULD STINK OF GAS FUMES just like mine. Likely worse as I have already done considerable work to help the issue.
Please, get your head out of the sand. Denial is a river in Egypt, has no place here.
I ride mine in central Florida and only have the gas smell after a long, hot, hard ride. And it dissipates quickly.
How does that make me in denial?
It doesn't. you just stated yours has what most of us call a defect. My comment was only related to the posts that state their bike does not have this 'characteristic' at all. The fact that it does not bother you or you work around it is just honest. It obviously bothers some more than others. I will readily admit I am very intolerant of gasoline fumes. They give me very bad headaches in mere minutes.
Well, I don't know about you, but most motorcycles I've owned over the years have had, to greater or lesser degree, the same smell after long, hot rides. I just associate with riding, I don't consider it a defect.
YMMV.
YMMV.
Fumes are one thing. I agree I have always had some minor smells on my Hondas. Drips on the floor is totally different. :yikes: nojoke
:clap:I would be more than glad to have them buy mine back and deliver a 2014 in exchange. :thumbup:Follow this link
US safety agency probes Can-Am motorcycle fires. You can view it at: http://m.apnews.com/ap/db_268743/contentdetail.htm?contentguid=7KUQanCl
