This is a post I made on another thread. Sorry I don't know how to insert a link to it, so old fashioned copy & paste.
To link the thread, simply
Select &
Copy the
entire address line in your browser's address bar (it's up the top of the page, where you normally type in
www.spyderlovers.com or whatever to open a website
) & then when you get to where you want to insert that link in your text, put your cursor in the spot you want it to go;
Right Click & then click on
Paste from the drop down list - that'll paste the '
www.whatever' address which you copied into the text wherever your cursor is (btw, it helps make it easier for readers if you put each link on its own line! See the example below
) & then when you get around to submitting the post, the Forum platform/software will add the URL commands onto each end to make it work as a link like the one shown below! :thumbup:
[.url]https://www.spyderlovers.com/forums/showthread.php?152001-Sprocket-Recall-What-s-Wrong-With-BRP-s-Logistics[./url] {I added the .'s to make the bits between the URL delineators appear as plain text, so this one ^ won't work, but if you give it a go as described, I'm sure yours will!
However, if you want to insert the whole
post you made elsewhere as a
quote rather than just linking the thread (see the link just above vs the way your post in the '
This is the post I made in another thread...' thread at post #337 above looks now
) then before you start posting here (or if you know how, just open another window
) find the other thread & go to whatever post you want to quote, where you need to click on the '
Reply with Quote' button in the desired Post's bottom right hand corner to get the post & all its embedded commands displayed as text that you can copy; then
Right Click followed by
Select All from the drop down list; then
Copy from that drop down list before selecting
Cancel in the bottom right hand corner of that post in the thread & then either open or go back to the other thread where you want to put that quote into a reply (so that's all clear now??) . Once you're in the thread where you want to post, quoting the stuff you just selected, open the
Quick Reply or
Reply to Thread text field & put your cursor in the spot where you want the post you just copied to appear as a quote; then
Paste from the drop down list & the import quote job is done! So now, just make sure you don't type anything between the
[.QUOTE] &
[./QUOTE] delineators or it'll be inserted/appear as part of that quote; finish typing in whatever other text you wanted to go with that quote & then hit
Post Quick Reply or
Submit to finish the post & add it to the thread!
hyea:
And while you might think from seeing all this ^^ that it might be too hard to even bother trying, it's really a whole lot easier than it looks!
Actually doing it is a lot easier than just reading that ^^ lot!! :roflblack: And believe me when I say doing it's a a
whooole lot easier than thinking thru the process step by step and then typing it out & describing like that ^^ so you can learn & improve your posting/Forum experience!!!
You simply need do it - just set your mind to it & work thru, taking each step along the way, and do it a few times. So go on, give it a go - you really aren't going to break something here or on your own device (altho maybe don't try it on anything important/legal documents just yet tho!
) And if you need a hand, I'm usually not far, only a PM away - & if you give us a yell, I or any of the other Mods will be happy to help. :thumbup:
