Lights for the RT622 Trailer
I really need counseling I guess:shocked:. I had so much fun adding loads of lights to the Spyder, that I HAD to do something to the trailer. This is the 2011 trailer which uses only 4 wires:
A= Ground
B= Tail Lights (both)
H= RH Brake & Turn
J= LH Brake & Turn
Pretty simple actually. I tapped the
Ground and
Tail Light lines inside the back of the trailer as a source of +12vdc and -12vdc. I got a 4 zone remote light module and mounted it in a vacant spot in the back of the trailer.
A little velcro holds it nicely. As you can see, it's super simple to wire up. Here's how I wired it
ZONE1= Interior halo of super bright white LEDs
ZONE3= LED Backup Lights
ZONE4= Purple LED side throw and general PURPLE accent lights
This remote has the multiple dimmer/flasher/breathe modes. There WILL come a day when I'll swap it for the new Black Magic remote.
Installing the LED strips is really straight forward. Getting all of the wires back to a 'central' place is a bit of the head scratcher, but I got it. For the front hatch, there was this solution...
Black clothgaffer tape works VERY well. I may end up getting some extra wide black plastic '33' tape to replace the gaffer tape. The black wire that is tiewrapped to the hinges is called Rotor Wire. It is #22 3 conductor that is very flexible and the coating does a good protection job.
Here's what the rat's nest looked like before I cleaned it up and put the plastic shroud back in place.
The blue shroud is for the new backup lights I added. Funny thing... BRP uses the same housing as they do on the bike. They and all the parts are made in Italy by CEV. On the bike, the backup light holders actually hold a light. On the trailer, the same holder is filled with some black stuff, capped with a silver reflecter, wires cut off and duh. They plug a hole. I TRIED getting the lamp holders from CEV, but no luck. Thanks to a brainstormng session with Len @ Cowtown, I got GM lamp sockets, cut off the 'ears', wired them, and used silicon seal to hold them snug in the holes! Thanks Len! Here's the results....
For now, when I backup at night, I'll use the remote to power up the #3 Zone and whaaaaa la.
One task was rather tedious. The side throw LEDs only came in 18" lengths. The longest I needed, to do a ring around the hatch, was 96". Break out the soldering iron and very short wire, heat shrink, torch and the magnifying glass. Not sure how, but all of the work to extend the light sets worked!
All in all, a fun mod. The total current draw of all LEDs lit is less than 2 amps! Basically no drain on the circuit. I'll have a few 'portrate shots' showing all of the lights soon.
