After some Guidance on how to route wiring in my example?
askitee
A few years ago, I added a set of driving lights to my RTL, then later a trailer bypass relay and some cameras.
Overall, the setup works great, but there are two issues I haven’t been able to fully solve:
  1. The messy “rats nest” where all the project wiring converges at the ground/fuse block/relay area.
  2. Occasional water getting into the relay area — is there a reliable way to waterproof relay housings and their connectors? (I took a shortcut and sprayed Flex Seal over the fuse block housing leaving a "window" for the fuse block status LED.)
For those with experience designing and building custom wiring looms - what principles or logic do you use to keep things tidy and protected that I might be missing?
Before running the cables, I thought through a few lessons learned from earlier setups:
  • I made sure the lights could be easily disconnected for bike servicing.
  • I routed the cables away from sharp edges or objects.
  • I used waterproof connectors wherever possible.
  • When I had to use crimp connectors, after crimping I sealed the wire entry points with liquid electrical tape.
  • I zip-tied the wiring looms securely to protect them from vibration or movement.
  • I installed a mini fuse block to draw power from the battery, with an inline fuse on the feed line to it to protect against things like water flooding the fuse block.
  • I also created a common ground/earth point, which later served additional gear like the camera and trailer supply.
I avoided photos as I was hoping to get the "concepts" of when you guys look at a wiring job and say how you attack a task. I tried to think of the problems I would encounter by walking thru it and was able to address most but the last two.
  • Do you group/bundle wires from the left side together or does that create a problem at disassembly? Ditto for the right?
  • Do you add connectors at certain points to facilitate disassembly
  • As an example - the Camera recorder is under the seat, Driving Light relay under the fairing, trailer bypass relay is in the tail.
It sounds to me like your thinking is "on the beam" and ahead of 99% of people who consider themselves electricians. My only contribution is to say that I would much rather add a wire to an existing harness than make up a new one. But I have done it both ways.
