Melted Master Cylinder Reservoir
bamaryder
We have 2200 miles on our ST limited and when we got back from the Owner's Event the brakes started smoking. then we got a brake failure light. I took it to the dealer and they said that the master cylinger melted. Now they say that BRP told them to hold my Spyder until they can design a heat shield to prevent that from happening again. I've heard that this problem has happened to others and I am wondering why there hasn't been a recall? I am also thinking this could take a long time and I will be Spyderless.
Is your ST at Halls?
Not sure how the st's exhaust... if it has a 30 lb. cat or not but i can see if the wind blowing break fluid onto the cat, may have contributed to the rt's fire that was posted?
Seems to me..!!
there is a problem. Don't know the changes made to the existing frame and design to come up with the ST but there seems to be a miscalculation somewhere. Hope they realize this and make the changes needed soon...:gaah:
DOT 3/4 brake fluid will burn but it's not considered a combustible substance so wind blowing brake fluid onto the outside of the cat would most likely not ignite a fire.
Probably not, but it sure makes a mess. That stuff's corrosive.
You would think the engineers/designers at BRP would figure out by now that when you have a motor and exhaust enclosed in so much Tupperware, it is essential to control the heat under there?:dontknow::dontknow: I think they better get things straightened out quickly as sales will drop if word spreads about dangerous heat levels on these machines!:lecturef_smilie: Hot to touch gas caps, burning Rt,melting master cylinders :yikes:and hot seats are just not normal, I don't care what anyone says! I have owned a few bikes over the years and never had any of the heat issue that the Spyder is having. Luckily I have not had any with my 2012 RT, except a bit of a hot foot, but I wear good boots and it is bearable. But I am keeping my fingers crossed!!
Harvey at Spyderpops can cure the hot foot on the 2012 RT for a real low price, give him a call 501 627-4008 :thumbup:
Cruzr Joe
I'm wondering whether anyone has thought of replacing that large black "cover" over the rear wheel with a grille...???
Like this
images
:bbq:
