Good Evening. I require some advice from you good people who know a lot more than I do about this.
After commuting to work daily on the Spyder for almost a year, it went into limp mode, and had a bad knocking sound coming from the engine. Given the location of the failure, I had to drive it like this for a total of 10 miles. I took it to the dealer, and they determined that the oil pump was not working, and they replaced it, but they then told me that the engine was still making a bad noise and it required further repair! They quoted me $12K for a brand new engine from BRP and $1200 to swap it out; but wouldn't quote me for an engine teardown & rebuild, which I have to assume is because they didn't want to do that work.
When I picked the Spyder up, we rolled it onto the trailer; and after I got it home, I had to crank it and hear the bad noise for myself. I have to say that it was not as "bad" as I expected; mind you, I know that "bad" is a relative term. I mean, I heard a ticking noise that was louder than it should be, but that quieted down a little bit after the engine was running for a few seconds, ie. after the oil pump had done its job of distributing the oil to the engine parts after sitting for so long.
I have found a shop, not a dealer, where they are willing to tear down the engine and go through it and the transmission very thoroughly, flushing out every bit of metal that may still be in it. They've quoted me $1500 to remove the engine and put it back after they're done; and $7-8K as a worse case repair that requires machine work. They said that if it requires machine work, the expense goes up quickly. If no machine work is needed, then the bill would be less.
So my question is... What is the most likely engine component that has been damaged in this case? Am I naive to think that just because I only rode it 10 miles and the noise isn't that bad, it will be a simple inexpensive repair; or is the worse case scenario still most likely? Should I scrap the engine and try to buy one off eBay from a wrecked Spyder? That was my first thought after the dealer gave me the news, but if I have it rebuilt by this shop, at least I'll know what I have, rather than the unknowns of a wrecked engine implant. Also, having it rebuilt by the shop opens up the door for installing aftermarket performance parts, like higher compression pistons etc in a way that wouldn't add any additional cost if they have to be replaced anyway. This shop also tells me that they can do a custom tune if I want them to.
I welcome and appreciate your thoughts/advice/comments. Thank you for reading this long post!
