Question for everyone: I'm 6'4, 250lbs. Front shocks are set at 3 and rear I have set at 3. I run the stock tires using the BRP recommended inflation (25 front, 28 rear). Is there a way to determine ideal shock settings for my weight to minimize the front-end wander, especially on bumpy roads and curves, or is it just a matter of getting used to the difference in ride than that of a 2-wheeler? Taking a ride out to the Blue Ridge Parkway and Maggie Valley in a few weeks, so trying to get the bike set up as good as possible to minimize steering hop/wander for a smoother ride.
Before you start playing around too much with the shock settings, try actively relaxing your shoulders, dropping them & your elbows down, and easing your grip on the handlebars; then looking waaaaayyy ahead and gently
guiding your Ryker where you want it to go rather than responding to every bump in the road &/or twitch in the steering. Because you've likely got more than DOUBLE the tire footprint under your Ryker than you had on the Harley, AND there's 2 wheels up front, there's invariably going to be more feedback from the road and the ride & steering will feel 'busier' than the Harley ever did; but by
not fighting it, scanning well ahead, planning your path waayyy out there, and then
NOT concentrating/fixating on the close in stuff, so that you can loosely guide your Ryker around the big hazards and gently guide it back on track after absorbing the littlies, you'll find it a lot easier & more relaxed riding. :thumbup:
Apart from that, a proper wheel alignment never hurt any Spyder/Ryker; that swaybar upgrade will've made some difference; and once you've worn out the factory fitted, vaguely round, black excuses for tires called Kendas, fitting a set of quality car tires and running them at an appropriate (lower) pressure for the significantly lighter loads they'll be carrying will make a vast improvement in your ride and handling, braking, traction etc...
hyea:
And IIRC, there's an a/mkt 'Steering Damper' and a fix for the 'Ryker Left Turn Issue' (search on that!
 ) that might help too!!
But aside from that lot, you will find that having 2 wheels up front does make for a bit of wandering and a 'busier' ride than you're used to - but it's not a Harley, it's a whole lot more fun!! nojoke - At least, it
will be once you get properly used to it; you iron out the 2 vs 3 wheel bugs in your riding style; you fit a good set of tires & run them at an appropriate pressure; and you really start developing the (different) riding skills needed to get the best from your Ryker!! Saddle time is your friend! In the meantime, check out my sig line... :thumbup:
Ps: Please check out my note re
NOT using post titles in your post above. Thread titles that briefly ask your question on a new thread are fine, but if you're posting a reply in an existing thread, then please, just leave the title field blank.
