Took the Spyder out for a good trial run yesterday. We have a loop that we ride, Victoria, Port Renfrew, Lake Cowichan, Duncan, home to Victoria. The road out to Port Renfrew is a nice twisty, but bumpy ride - good suspension is a must otherwise, you know just how much travel the suspension has. This road is under construction, lots of dips and dives in the most inconvenient spots, and is a mix of pavement and tar/gravel. Port Renfrew to Lake Cowichan is twisty as well, a tar/gravel road top, with a good amount of dips that test your suspension as well. The ride was good, but I did use all the travel the suspension had, and bottomed several times no matter what air pressure setting I used in the rear shock - spring rate not sufficient for the task. The ride on these two legs of the ride reminded me of a snowmobile motocross course - in/out of turns, speed up - shed the right amount of speed into the next corner, left turn/right turn, hang out the side, and on turns that are not banked in your favour. On roads that have corners that are not banked properly, the Spyder is not the vehicle of choice. I was glad to get back onto the civilized paved roads. Not to say this is not a road to ride, but will now know that when Sonya and I ride the Spyder on this trip, speed is not your friend.
Brought to mind, again, the need to replace the OEM suspension. More reading being done, and refreshing the memory on compression/rebound settings and why these are important. Video viewing of the various aftermarket shocks out there. FOX shocks has some good videos explaining rebound and such.
When I had my demo day before I bought my Spyder, the demo was a 2020 RT LE. It did not have a sway bar upgrade, and did lean more towards the outside of turns. One of the videos on rebound by FOX shocks indicated that rebound can be set for varying conditions and that roll in a corner is one of these. The faster the spring returns back to original length in the corner, the less roll there will be. I mention this because when my Spyder enters a corner, say on a cloverleaf, the front end does squat and lean, maybe not a lot of lean, and in doing so with the OEM shocks, does not actually rebound until it comes out of the corner. What would be nice is for the shock to rebound fully, or partially while in the corner. Couple this with how fast/slow the shock compresses would be beneficial. A different spring rate is also helpful.
After yesterdays ride, a new rear shock with a stiffer spring rate may also be beneficial. A spring rate to better accommodate Spyder weight and approximately an additional 500 pounds of rider/pillion/luggage weight may be in the offing.
One more consideration in a suspension upgrade is it is not inexpensive, mentioned this in an earlier post I think. Looking at Elka stage 2, possibly Stage 3 shocks, front/rear is a $2000.00 CDN before tax proposition. I understand why a suspension upgrade is not on the lists of the majority of people. The good news is that we are not touring this year, chews up a good chunk of change, so I might as well support the economy and do some mechanical upgrades on the Spyder, my '85 1200 Goldwing Limited Edition is almost maxed out.
Lots of issues to consider.
