Rednaxs60
Have been reading the owner's manual to find out about the fuse blocks, specifically if there is an accessory connection. My 1500 had this, 5 amp circuit that you connect to. Would like this for a trigger wire for the accessory fuse block I intend to install. I will find a suitable wire.
Looked at maintenance intervals. The HCM filter every 30K Kms, going to be a while for this, only at just over 10K Kms. Put some 1K Kms on the Spyder in the past two weeks, like riding it, so does the Mrs. HCM filter on order and will be changed when I do the oil/oil filter.
Recommendation is to replace brake fluid every two years. I mentioned in my previous post that the B.U.D.S. diagnostic software arrived yesterday, will be using it soon. Have to order Speedbleeders to do this, being a one man DIY. Good time to have a look at the brake calipers and maybe a servicing.
Coolant is to be changed every 5 years, been 7.
Do the brakes, coolant, HCM filter and oil/oil filter change for the first baseline work/maintenance period. HCM filter on order, maybe end April. Thinking that changing the HCM filter is a spring maintenance issue, Bertremington instigated this.:2thumbs:
Still waiting on the 2013 OEM service manual - in transit, and will order the 2014 supplement ,from the dealer - haven't been able to find a used one.
