ofdave
Have been interested in this since the beginning. When I found that fretting resulted in the iron oxide production I posted the Wikipedia link to it in an earlier post thinking it would spark thinking on the subject which it has.
Our Spyders are not the only machines with belt drive pulleys on an output shaft. Nearly all motorcycle manufacturers have a model with belt drive from BMW to Honda to Harley to Yamaha and more.
I am curious if those others have the same issue? We can't be alone in this, can we?
I understand the concern over bolt tightness. It seems to me the bolt holds the pulley on the shaft to prevent lateral movement while the splines prevent or minimize rotational movement. From what I've read, I think the rotational movement of the pulley on the shaft is the main cause of the problem although I can see where any lateral movement of the pulley on the shaft would exacerbate the problem but not be the actual cause.
I agree with Freddy, putting the bike into gear is not a cause of the problem, it is the minute movement of the pulley on the splines that gives us the problem.
I wonder if belt vibration could be a contributing factor to this movement of the pulley? Are the pulley failures equal among bikes with and without belt tensioners? Food for thought
It is interesting to hear what solutions have been discussed-lube on the shaft to reduce friction in the minute movement of the pulley on the shaft and RTV to keep out moisture and maybe a cushioning effect. I hope there will be future posts on the success of each method.
The one issue that has not been talked about is the material the pulley is made from. Would a different harder alloy reduce the fretting? A problem I see in making the pulley too hard would be transferring wear to the output shaft. That would not be good as shaft replacement would be much more expensive than replacing the pulley.
A comment was made above that someone installed a new pulley and was told by his dealer that although it had the same part number it was different. Could it be that BRP changed the make-up of the pulley to harder material to reduce the problem? Would be interesting to know the answer.
Anyway, the saga continues.
