GaryTheBadger
Thank you, Roadster Renovations.
My dealer seems to be having a delay in acquiring Loctite 660 to go with replacing my shaft and bolt. I have shopped four automotive stores and can't find it either. But all of these stores carry a lot of Permatex products. So I got the idea of Googling a Loctite 660 equivalent. It immediately came up with Permatex Sleeve Retainer # 64040. Has anyone used this product and will it accomplish the same result as Loctite 660? In reading the product information for the Permatex it looks like it will.
My question was if the Permatex product that I mentioned would work?:dontknow:
I wouldn't do anything more. Tightening the bolt any will break the loctite seal and render the thread locker useless. <snip
BRP does not agree, or they didn't 6 years ago when these failures first showed up.
http://www.spyderlovers.com/forums/...ft-Pulley&highlight=sprocket+service+bulletin
http://www.spyderlovers.com/forums/showthread.php?18252-Front-Sprocket-BRP-Bulletin
As I said earlier, I torqued mine to 115 ftlb. The SB said to mark the head of the bolt with a black X to show it had been loosened and retorqued. I wonder to Doc still has that SB somewhere?
Saw my first RT with the problem in my shop on Sat. Bike had 58,000 miles and the pulley covered in the red iron oxide. Recommended the owner have the dealer replace the pulley. (its under warranty).
Kevin Cameron's Top Dead Center column in this month's Cycle World Magazine speaks directly to the cause and source of the dreaded Red Dust:
https://www.cycleworld.com/long-and-short-motorcycle-fasteners
"(The)loss of metal from the slight relative movements between fastener and part caused by vibration. A good example of this is the loosening of the large, thin nuts often used to retain engine output sprockets on their shaft splines or of the several bolts used to retain rear wheel sprockets.Despite the usual presence of a torsional shock absorber, built into the clutch basket, the drive from engine to rear wheel is not smooth. All the tiny motions that result cause surface scrubbing, each such movement making a zillion micro-welds that are broken by the next movement. In steel-to-steel contacts of this kind you may find a reddish discoloration or even red powder—the iron oxide that results from “frettage,” the slight vibratory weld-and-break action between surfaces."
This thread did (finally) cause me to check my bike for that evil red rust so my hat off to those who argued with me on what I considered a non-issue at the time.
P.S. Don't think for a second I will not call BS in the future, I was wrong this time.....:banghead:
My take on the above explanation of fretting is that it's not so much the clunk you describe RR, but the power pulses from the engine itself causing the damage due to 'inadequate clamping force' of the pulley retaining bolt as BRP advised 6-8 years ago. As I've mentioned earlier in this most interesting, if not distressing topic, I torqued the bolt on my 990 higher than BPR's revised spec after determining what a new bolt of that type could be torqued to, then added a bit more due to the factory-fitted thread locker. We've already had a few reports of the bolt tightening up when folks have retorqued it. In the service bulleting I referred to earlier (which seems to be unavailable to view these days) BRP instructions were to loosen the bolt then retorque it.
I don't have a 1330 bolt at hand but maybe someone can measure the bolt diameter and thread pitch and tell us what markings are on its head.
...........and another thing. Why did BRP fit a 'flywheel' to the 990 drive pulley after the spline failures were detected? Was it to behave as something like a vibration damper? I note that the 1330 does not have this. Very curious.
