Roadster Renovations
Had a friend/customer loose his splines on his F3 Ltd at Spyder Adventures. We were able to verify by removing the plastic cover for the front sprocket. His did show the telltale rust around the front of the sprocket. I highly suggest that ryders periodically (ever month or so) pull that cover and look for the rust. Just looking under the byke is probably not good enough.
What happens, the splines on the sprocket start throwing metal shavings and they appear as red rust. By pulling that cover (2 min job) it should help you to catch it before it goes completely out and you are stranded.
My friend was very lucky and Blessed. Out of all the areas to ryde, many without cell phone reception, his grenaded (total part failure) right next to the Maggie Valley Inn at the stoplight!
You might not be so lucky!
I know this topic has been posted before, but to my knowledge no one has suggested pulling the inspection cover.
