bayoubill
so i got my rs out yesterday, no clutch, i checked and it was leaking out at the diaphragm cover area, the large o-ring on the piston looked like it had been shoved in dry at assembly it was cut off flat in spots, no real wear anywhere, anyway i cleaned the bore with 1000 wet or dry and ordered new o-rings, will the clutch slave cylinder piston bleed just filling the master and pulling the lever and loosening the slave bleeder just like a brake will or is there some other procedure i need to do?
