millerrdjr
2014 RT-SM6 with 32000 miles.
I had a problem with the clutch not disengaging and replaced the slave cylinder (BRP calls this the Hydraulic Cylinder).
The new slave cylinder corrected the problem for a few hundred miles.
NOW, I cannot operate the clutch lever. It will not move.
Had this happen earlier after the slave cylinder replacement and was able to free it up with repeated attempts to operate the clutch handle.
It happened again while on a trip and I could not get the clutch handle to move.
When I open the slave cylinder bleed, the master cylinder handle moves freely and pumps the fluid out the bleed.
The clutch seems to be stuck in the dis-engaged position.
Could this be the clutch actuating rod sticking?
Disgusted and haven't torn it down yet.
Any thoughts are welcome.
