2022 RT Ltd - fan ran the entire ride home & then would not shut off, even when I shut off the Spyder - anyone else? Any ideas?
I was riding my bike for several hours today, with no problem. We stopped to eat, then noticed on my way home for 45 minutes, the radiator fan came on, and ran all the way home. Even when I pulled in the garage, it was on. Shut off bike, and fan would not shut off. Had to disconnect battery to shut off. Reconnected battery about an hour later, it was still running, so had to disconnect again, and left it that way.
Anyone else hear of this situation, and what caused it?
Dealer can’t get in for week and a half.
Have you checked the antifreeze/water level? Similar thing happened to a friend and it was extremely low on water, to point the motor would shut down.
Check the obvious things first, then go to the manual and read up on the thermostatic fan controls. The water gets too hot, and a sensor turns the fans on. When the water cools back down, the sensor is supposed to turn the fans back off. That is a simplified version, but the answer you seek is somewhere in there.
When all else fails, read the instructions............they are in the manual.
Had a similar issue on my 2020RTL a few years back and it was a sticky relay. Banged on it a few times and it stopped. Did not happen again. The fan will run after key off on hot days to cool down engine.
Hey Steve and Belinda. Looks like a relay issue. While the fans may run a short period of time after turning off the key, they certainly don't run long enough for you to go get your tools, disconnect the battery, and come back an hour later, with the key being off. The attached pic is of your Right Side Fusebox. Remember - RIGHT SIDE AS YOU'RE SITTING ON THE BIKE.
The relay that controls the fan on/off is lower left. The big one. If it's stuck, it draws power directly from the battery and runs the fans. You can just pull that out, reconnect the battery, and see if they stay off. These BRP relays have automotive equivalents available out there, if "smacking" it doesn't suit you. Just go to the auto parts store of your choice and match it up. Much less expensive than BRP OEM parts. Plus, automotive equivalents will probably be in stock.
During the VERY HOT summer of 2021, on my 2018 F3, I too had the problem of the fans not turning on. Sure enough, it was the relays. I purchased the relays (both left fan and right fan same as OEM) from Amazon and the fans have been operating normally ever since.
Here's what you look for on amazon: Song Chuan brand
Relay for Polaris Sportsman Ranger 400 500 700 800 50A Relay 50 Amp, 4011141 (Pack of 2)​
Do the fans run when the ignition is on and the bike is cold? if so, check the coolant temperature sensor, which is basically a resistor. If it is bad or disconnected (wire off), it would make the fans run continuously. Other question: does the bike overheat although the fans are running? It happened to me at about 45000 miles and the problem was dirty radiators. No air would pass through them. I carefully cleaned them and that fixed it.
Just be aware guys, that this is a thread from the beginning of the year, so given that we haven't heard any more from @SteveandBelinda, it's probably no longer an issue. That's why it ALWAYS pays to check the date a thread was started before replying, and check the dates on the last few posts too. ;)
Still, it's not real thread archaeology, being just a few months old - so if it has been resolved, they juuust might see these new posts in the thread they started back then and come back to tell us how they resolved it in the end, or if they actually did?! :unsure:
Just Sayin' :)
It happened to be the fan relay. Thanks for all the help
Same thing happened to us on a trip on our 2021 Can-Am Spyder RT Limited. The fan would not shut off. Got into town; the Wife got on the Internet and found out that if you tap the relay, it will turn the fan off. So I tried it; first, I gave it a small tap; it turned off no problem and hasn’t done it since.
Then I saw a different post about getting new relays from an auto parts store and heard that you can get them there. So now that I know I can get a relay at a regular automotive parts store I thought I might as well get a new one and put it in. Thank you very much.
Ps: I cannot do the pictures of the part.
The Part maker is Import Direct OEM Replacement Parts
25-0299
443-951-253K
Relay
Made in china
That’s all I got. Not sure what auto parts store, but you can probably cross-reference from any auto parts store part as long as you have the numbers.
