Chupaca
Little checking
On the vaccum hoses.... there are three.. one larger which is not the problem and two smaller ones. One is clearly visable close to the larger one and the other is behind the canister...just so you change both and we recommend the silicone hose...:thumbup:
Thanks for following up and letting us know...:bowdown:
Getting back to you guys on my problem. Had nothing to do with a valve adjustment like I thought. I pulled the fuel filter off and could barely blow through it. I got one that fit from napa, wasn't the oem one but fit the fuel lines (Napa Gold 3032 fuel filter, less than $5.00), it does not fit in the OEM mounting bracket but there is plenty of room for it to place with the OEM bracket removed (no wire ties needed). Will get the OEM one eventually. The bike runs and starts fine now when hot, its also not popping as much. I have a Hindle on no fuel management controller (i know i need that just never spent the $$$). I pulled one of vacuum hoses off and didn't realize the two were different ID sizes, so only replaced one. They were clearly not an issue, no cracking or failing at all, will replace the smaller one over the winter just to say "both were replaced".. Hope this helps some of you all.
