Ok, so not much to report other than more disassembly. First thing I removed yesterday was the Hindle exhaust system. When I had the trike running, I thought it was kind of loud and sounded like it had an exhaust leak. Well, that was confirmed. I guess whoever put on the exhaust system didn't install a new gasket on one side as seen in the photo below. The pipe on the right is missing the gasket. Makes me wonder how quiet the trike is with the gasket in place?
Next I started to remove the following items in this order:
1. Rectifier
2. Left side support bar
3. Right side support bar
4. Brake Master Cylinder and Reservoir
5. Passenger foot pegs
6. Rider foot pegs
7. Rear fender and mounts
8. Airbox
All of these were pretty easy. I tried to take out the fuel tank, but it looks like you need to remove the engine before that can come out. When removing the fuel line connectors from the fuel pump, I managed to break the little black restraint clip on the fuel line going to the fuel pressure regulator. I found that you can buy just the clip separately, so that was ordered.
Also picked up the seat and I think it looks ok. I might just redo it. Guess it was a mistake to give the upholsterer a choice on how he wanted to do it. hahahaha
I'm taking a lot of pictures along the way so I know how to route the wires and where the tie down points are. If you guys want to see a specific area, let me know. After a couple hours of work, here is how she sits. I'm going to try and leave the radiator and oil reservoir attached to the engine and remove it as a whole so I don't have to mess with those clamps that they use from the factory to connect the hoses. Hopefully I can keep everything intact.
Anyone know how to use the tool that is used to lift the engine out from the frame? I didn't purchase one, but If I know how its used, i'm sure I can cut one out from my CNC machine. 3/16" steel plate looks like it'll be strong enough to lift the engine out. Maybe even 1/8"? It looks like it just hooks onto the engine between the cylinder heads and you lift the engine a little then pull it out from the right side. Anyone can confirm that?
