Page 1 of 2 12 LastLast
Results 1 to 25 of 33
    Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Default Is the 7Jurock windshield any good?
    Has anyone had any exposure to the 7Jurock windshield? I like the flip design but not sure if it's going to make a difference from the stock windshield I have on my 21 RT.
    2021 RT Base Model - Petrol Blue / Top Case Decal is the 1st of its kind for RT base model from wrapmysyder.com.
    2021 RT , 1.5 inch pedal riser, Full size brake pedal Petrol Metallic Blue
    Jun 2011
    Near Lexington, NC
    Yes the flip does help. Had a couple on previous F3T, one wider for winter use. As with any plastic windshield, perhaps with exception of F4, they do, over time, get micro scratches from cleaning, no matter how careful you are. I am considering one for my recently purchased '22 RT to see if a shorter one will allow me to look over. I can not with the current OEM although it does a good job other than having to look through it.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT
    2014 RT
    2016 F3T
    2022 RT current ride
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Dec 2013
    If you type '7Jurock' into the Search field up toward the Top Right of the Page, then click on the 'Search Titles Only' field before submitting the search, you'll get about 2 pages of results back, and from the thorough cursory glance that I just gave them, it certainly looks like most are pretty happy with them, but there's a lot more detail in there that's probably worth you reading!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Aug 2020
    CA
    Short answer is yes, I like mine.
    21 Spyder base F3
    Jul 2021
    Vancouver BC and Palm Desert CA
    I have had two of them. The flip is great, there’s a little distortion but they are excellent value for money
    2021 Spyder RT Limited (Palm Desert)
    Grey - dark edition
    2015 Spyder F3 S (Vancouver)
    2017 Yamaha V Star 1300 Tourer
    Sep 2016
    Chillicothe, Oh.
    Yes
    2015 RT , Black
    May 2021
    Upstate NY State
    After reading the reviews of many, including here, I have decided it's the right choice and will purchase it as soon as I get a little extra cash. Thank you all for your feedback.
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Quickdraw View Post
    So which height are you getting and why? It seems to me that most people are going smaller but, I want to go with the tallest one.
    May 2021
    Upstate NY State
    Quote Originally Posted by K80Shooter View Post
    I'm thinking 25". I'm 5' 10" (yes Peteoz, I'm short to you, but most are) and think anything taller than 25" would be too much. I like looking over the shield but still like the wind protection.
    Oct 2021
    Wichita, KS
    I bought one used here on the forum with the flip. I installed it, rode with it for a day, and then uninstalled it that night. It had such bad distortion when looking down at the road through the flip I just couldn't stand it. It actually gave me motion sickness. I just couldn't do that to someone else so I threw it in the trash. I do not recommend them at all.
    There's no place like G28 X0 Y0 Z0
    Feb 2020
    Minnesota,USA
    The 7 Jurock can be ordered with or with/out the flip, tinted or not, even made to order.
    I bought the 25" with light tint and the flip. I like it because it's wider than OEM and the flip distortion of viewing doesn't bother me as much now as when I first installed it. You won't find a better price for a windshield anywhere else that I could find and they do have discounts available sometimes. I would buy again if needed. Bill
    2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
    Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
    BaJa Ron Ultra 3 pcs sway bar kit
    7jurock 25" tinted windscreen w/flip
    Frogman Dave's "Signal Button"
    If in Doubt, Don't Do It!
    " Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
    Feb 2020
    illinois
    Have a 19" on my 2022 F3L. Look over the top and is a good improvement over the oem.
    Aug 2019
    Stoughton, WI
    My new 7Jurock arrives tomorrow for my 2022 RT S2S. Removed my OEM shield today in preparation. My 2022 shield doesn't use grommets/steel sleeves for attachment. Will the 7Jurock arrive with the same screw hole sizes as the OEM ?? Thanks
    2022 RT Sea To Sky
    2019 F3-S , Monolith black
    Active Member johnv50's Avatar
    Jun 2018
    Tonawanda, NY
    I just put a 22" 7jurock on my F3t, it is my 3rd shield from them, I like to look through the shield. For the price they are excellent and they will custom make them to your specifications.
    johnv
    USMC RETIRED
    BLUE KNIGHTS NYV
    2022 F3T Glacier Blue
    Aug 2020
    CA
    Mine did. At least compared to the Route 129 it replaced.
    21 Spyder base F3
    Aug 2020
    CA
    Quote Originally Posted by FrogmanDave View Post
    The flip is bent material which is always going to have some distortion. You are not supposed to look through the flip but over it.
    21 Spyder base F3
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Pirate View Post
    I'm 6'3" tall and bought the 27"/flip/light tint shield with OEM vent holes cut in. The OEM is 25" and when fully extended, it is at chin level. I prefer to look over the shield, not through it. You sit a bit taller on the RT models.
    2022 RT Sea To Sky
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    I have the F4 at 32". Not pretty, but it works, great for the wind protection. I will not ride without it.
    richie spyder
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    They are amazing!!! Give them a try.
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
    Dec 2020
    Hartwell, Ga
    Let us know how it works out. The 27"/flip/light tint shield with OEM vent holes cut in is the one that I want for mine.
    Aug 2019
    Stoughton, WI
    Just put on the 27" 7Jurock. It is light tint and flip type. Nice quality. $227/shipped and took about 17 days.
    2022 RT Sea To Sky
    Jun 2016
    Harrington, Australia
    Looks good troop. It might be time to bite the bullet and hang the shipping cost to Aus
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Nov 2022
    North Carolina
    I don't remember the height, but I replaced a stock Tall Boy which sent the wind directly to my forehead. All the other aftermarket pieces require their mounting brackets also, so I tried this one. I'm 5' 8" and look over the top. The width and the flip work great for me. Can't remember the young lady's name at 7Jurock, but she is awesome and will help get you what you need.
    2018 F3 Limited
    May 2021
    Upstate NY State
    I never got around to answering you K80. I ended up buying the 27" because with the new Corbin seat, I sit a bit higher and the OEM 25" windshield is too low now. With the 27", I can still see over it.
    Dec 2020
    Hartwell, Ga
    Thanks Quickdraw! I have decided to go with the 27" also.
