EdMat
Well-known member
Final update on original post
I'm sorry to report that all attempts to diagnose and remedy the LH multi-function switch issue of not downshifting manually, have failed (fixing the shifting issue just transferred the problem to the turn signals) and I ordered a new Multi-function switch assembly yesterday from a local dealer (PN 710008090) at a cost of $509.99 plus tax). I will install it myself, and already have the failed switch removed.
I don't fault the local dealer for BRP's failure to address and stand behind a known fault of this multi-function switch cluster.... BMW does the same thing. The local dealer's hands are tied, leaving me to fight the battle. So, right now, I'm finalizing plans on a 3,000 mile trip beginning July 4.....to the 3-wheel rally in Deadwood; Cody WY; Chief Joseph Highway/Beartooth Pass to Red Lodge MT; down to Yellowstone; and then heading back home.
BamaJohn, I think I discovered where you went wrong. The pic shows you putting the BB on the turn signal side of the switch. This pad is double sided. One side does the turn signals and the other does the shifting. You need to put the BB on the shifter side of the switch. Careful when you take the shift mechanism apart to change out the ball for the BB as there is a spring loaded detent ball that will come flying out. Fixed one today that way. I hope it holds up. Will try and do a better description later.
