Wiring help needed - Trailer turn signal lights reversed! Any ideas?
Jetfixer
Well-known member
Why do I get all the oddball problems? A friend had a 2023 RTL that he bought new. I added the BRP trailer hitch kit for him. All was well. Due to other issues, he traded in on a new 2025 RTL. I removed the trailer hitch kit from the 23 and installed it on the 25. He had to buy the extra wire (p/n 219401295) that is required. Prior to the 2024 model year, BRP included the possibility of adding a trailer hitch to any RT. From 2024 up, they removed the 12v power wire from the cargo wire bundle. This additional wire that is now required is piggy-backed into the cargo interconnect harness under the pillion seat and is then only a single wire running back to the trailer harness carrying the 12v power for the trailer module. Here is the problem: everything works great except that the turn signals on the trailer are reversed. He signals for a left turn, the Spyder lights all blink for a left turn, but the trailer right turn signal blinks. He signals a right turn, the Spyder blinks on the right, the trailer blinks on the left. Not that it makes a difference, but he has a freedom trailer. I plugged in my RT-622 to his bike and it does the same thing. In comparing the 2023 and 2025 wiring diagrams, everything stayed the same except for the lack of the 12v power wire on the 25. Any ideas?
Something got swapped either in the harness manufacturing or the electronic isolator and it really does not matter. The easiest thing to do is to Just correct it at the interface between the trailer connection on the bike and the bikes adapter module. Swap the green and yellow wires. This will involve cutting the wires and re-splicing them. If you wanted to dig in further the connector between the bikes harness and the isolator should have removable pins for those wire, but to get to it you have to pull the back tail panel. Just more work.
I’m not sure if this helps but when I purchased my new Freedom trailer and BRP wiring harness, the trailers turn signals were also reversed. I removed both tail lights and reinstalled them to the correct side. It’s been a few years but I think I just removed and reversed the sockets. I didn’t cut and splice any wires.
There should be a discussion concerning this in the archives.
Poasttown
2019 F3 L
That is my first suspicion since it all worked correctly from the 2023 RTL and is also wrong when other trailers are attached to it. I assume you are referring to the green and yellow wires in the gray Deutsch plug. Would you happen to have a diagram or the full pin-out for the trailer module? Trying to get him to bring it over today to solve this. I'd much rather re-pin the connector than to cut and splice.
No I do not have that diagram as it is not in the manual. I do have the entire stock unit in a bag as I built my own for a Bushtech tailer and you will see the green and yellow wires in the Deutsch plug to swap around. They are in pins 4 ( green) & 5 (yellow) on the module side of the connector while the Bike side has Gray/pink on 5 and Brown/yellow on 4.
