Wiring for volt meter
Looks good! Sometimes we just over think the task at hand. Been there done that.
Sent from my SCH-I545 using Tapatalk
Sweet!
Now, disconnect the other gauge, and a digital readout will appear, allowing you to put something else on the left! Like a USB PORT! 😄
Thank you everyone for your input. Especially Finless Bob, Cruzr Joe, and BillyBovine. After busting my noodle trying to figure out how to do it the hard way, I got the Voltmeter working by tapping into the orange and black wire just like you guys said to do. It works! :dg1:
attachment.php
Looks good, did you disconnect both gauges?
Cruzr Joe
Cruzr Joe
Yes, I disconnected both. It seems that you have to disconnect both gauges in order to get the digital display to work. So now I have a dead fuel gauge on the left side. I need to figure out what to put in that spot.
Thanks for your advice Joe.
Pam
I did. The digital display is working. I may consider the USB port as the next project.
Pam
I'm curious how this will cause water to go into the fuse box. I'm not arguing, I respect your advice BillyBovine. I'm just wondering what you mean by that.
Pam
Obviously water will permeate the gauge face and follow along the wire into your frunk and then into your fuse box!
OK, a lot of advise and some of it is contradicting... GET A MULTIMETER. Put it is VDC scale with black probe on black wire. I think it is the black that is ground. Put RED probe on one of the two other wires. Should be nothing on VDC scale. Turn key on. Should be about 12.5 VDC. That wire is switched VDC and what you want to connect to. You have another wire for gauge illumination. Wrap it to the hot wire and stick in into the plug there where you found the switched VDC. You want switched for the illumination. I put my identical gauge in the left side hole. It isn't really very accurate. Measures 12.5 VDC at idle and 13.8 VDC when the bike is underway. I have measured at the battery and the real output should be 14.2 VDC when the engine is revved up to about 3.5K rpm.
