HowTo: Windshield center arm replacement
I replace the windshield center arm on my wife's 2010 RT, and now the windshield wil not go up or down.
There is a magnet on the opposite side of the shaft from the gear. It's used to sense the position of the arm.
Did you re-assemble the unit and change the position of the magnet relative to the arm ?
I hope you bought a billet arm from noboot, instead of the same crappy arm from BRP.
As always, my free advice comes with a double your money back guarantee.
:agree: …. and to further complicate matters …. that magnet acts the same way that elevator - start / stop devices do …. they must be positioned correctly for the READER to sense where to position your windshield …………. 5 years ago when I built my own " windshield arm " I discovered this …. luckily I marked where the Magnet shaft arm was before I removed it ……...good luck ….. Mike :ohyea:
:agree: Marking the magnet placement before removing is the key!
Thank you for the info, I read the maintenance Manuel and watched the YOUTUBE video and nowhere did it say to make sure the RT was running. Thanks again.
Sorry about that, I guess we assumed you already know that your RT windscreen arm wont function without the bike running.
The simplest of things quite often catch us out.
Cheers, nobot
