Antenna Snapped, need a replacement - recommendations? And Shuddering at low RPM - any ideas?
Raknid
I had two bad luck items today with my wife's 2012 Spyder RT. First, I had a quite a bit of shuddering at lower RPM. I was concerned that it was the clutch but, after research, I think it may be bad gas. My wife has been ill the last several years and last year, it was not ridden many miles. I am going to get fresh fuel and add fuel cleaner on Monday and I hope that the issue resolves.
Secondly, I snapped off the antenna while closing the garage door and need to replace the antenna. Would folks here recommend going with the OEM replacement or is there an aftermarket antenna which is better?
Thanks and Happy Easter to those who observe.
Aftermarket, Copper's given you a spot to look, it will be a little bear to get the old out, but you can do it. It will have a lot of Loctite on it if it hasn't been replaced before, so clean the threads well before installing the new one, DON'T use Loctite!!! :cool:
As I recall, when I took mine off, I used a long socket, I don't remember the size, maybe 10mm, slipped it down the antenna, and used vice grips to loosen it!
@Jackhartjr,
Use a 7mm deep socket to loosen the nut and vice grips. I used the 7mm socket on my 2014 RTS-SE6 when I changed the OEM antenna after it broke in half. Sorry, but I don't have any pictures. Also, do a search on this site for the old thread: Removing RT Antenna
On the "Removing RT Antenna" thread, I posted a picture of the boot that sits on top of the tupperware on the back panel of the Spyder. However, I did not post any pictures of the inside, where the OEM antenna is attached. But that's where I used a 7mm deep socket to loosen the OEM antenna.
Deanna
