Tonylmiller
Short answer is yes, it will affect performance. At least maximum performance. You might not notice.
lets see if I got this right. so if I get like 20mpg on local street and 30 on freeway, I should stick to 91, correct?
All
Doing a 600 mile, many overnights, trip with our new (to us) 2013 Spyder ST/S the first of April. Wondering if using 87 Octane gas vs. 91 will change the performance during this trip. I think it was recommended either in owner manual or I picked up on the web to use 91. It will help on the money side a bit. Also this bike’s fuel gauge is off some. When it shows a half tank I put more than 3 gallons in to top off. Has anyone run into this with their gauge?
On the gauge thing.... most gauges are about 50% accurate.
So just a heads up.
Just to expand a little on that - most of those gauges are within about 50% of accurate OR somewhat accurate 50% of the time....But you'll never know which or when!
This is basically due to the irregular shape of the tank & the location of the pump/sender in the tank, so while you might get a slight improvement in accuracy by installing or using a new/different/more accurate gauge, at best it's indication is only ever gonna be a somewhat vague indicator of what gas might be remaining in the tank!! :cus:
So just like most of the rest of us, use your trip meter & fill up based on how far you've travelled since you last filled!. Just Reset a trip meter every time you fill up, do a few rough calculations to work out what your best & worst fuel economy might be so you can work out your average range on a tank of gas, then always try to fill up before you hit that worst case scenario! :thumbup:
These engines & their fuel pumps/injector systems REALLY don't like running too low on gas, because the gas remaining in the tank serves as both lubricant & coolant for those fairly critical components. So ideally you'll ALWAYS keep at least a couple of quarts/litres remaining in the tank - any less gas than that remaining in the tank risks expensive damage to the pump &/or injector system, and even if you think you might've got away with it on that one time you ran your gas lower than that, you'll probably never really know until one day the fuel pump &/or engine craps out on you when you least want it to!! :cus:
Don't rely on the gas gauge, and always aim to refill while there's still at least a couple of quarts/litres of gas remaining in the tank! :lecturef_smilie:
Tank by tank MPG calculations are an exercise in futility. Don't needlessly expend your precious ryding time doing the calcs. Now, every once in a while, like maybe every ten tankfuls, add all the gallons you've pumped in and all the miles you've ridden and calculate your MPG. It will be a lot closer to a number representing your real MPG.Hot Dam Peter! Thanks for the info. Running by the gas gauge, I've always wondered why I get 140 MPG and then 30 MPG? (exaggerating of course) The only real figures come after the tank is refilled with fuel. I'm very anal about my MPGs. I can now only count on the stations with older nonupgraded fuel pumps to truly keep an accurate account of MPGs. When the entire country is overcome with these new high velocity fuel nosels how will we ever know our true MPGs?
:agree: ..... Because of the GAS needed to cool the pump .... I have often thought about - WHY or HOW do the External " Fuel pumps " manage to work without the " gas cooling factor " ...... Mike :thumbup:
Those external pumps generally weren't asked to reliably & consistently deliver fuel at the high pressures (within a very tight range too) that modern EFI pumps are, and they were designed & manufactured so they'd work without the cooling & lubrication provided by the pump being immersed in the gas remaining in tank.... most successfully, some not so much!.
There's a few vehicles with 'external fuel pumps' that very easily come to mind as being failures in this respect, altho possibly in some (colder) parts of the world they might've been fine, but here in Oz they just didn't work well at all!! :banghead: . There's nothing quite like having your car stop every 20 miles or so on any day that gets over 25°C/77°F and then having to carry enough extra water for your trip so that you can regularly stick your head into the hot engine compartment (or into the depths of the trunk!) just to pour said water out over the fuel pump every time it gets vapour locked.... and then you'd hafta either crank it on the starter until you risked killing the battery or you'd hafta prime the bloody pump again! Sometimes needing BOTH!. And let's not forget the whole new world of frustration & pain that was juuust waiting for you when you hadta do all that even more often on HOT days! :gaah:
Once manufacturers learnt that putting the fuel pump into the gas tank meant they could run the pumps faster & deliver gas at much higher pressures because all of the extra heat generated would be absorbed by the gas remaining in the tank, fuel injection systems certainly came into their own, contributing to improving both the power delivered & the fuel economy achieved!hyea: . But by putting the fuel pump into the gas left in the tank so it could be reliably both cooled and lubricated, it also lead to the warnings you find in most Glovebox manuals these days about never running the gas tank to empty and always filling up when there's still about a 1/4 of a tank full of gas left in there!
It was a gift that giveth on the one hand, but taketh on the other! Not that I really want to go back to the pre-EFI days on everything tho.
:thumbup:
Which damage I don't recall anyone ever reporting on this forum.Allowing the ping to go on for an extended amount of time can cost you a cylinder head or two.
The octane rating essentially impacts the engine's ability to resist ping (called pre-ignition in the days of yore). A higher octane fuel allows the ECM to push a more advanced (think aggressive) timing. That's where the power boost comes from. The actual energy in a gallon of 87 is really the same as a 93, but the 93 gives the ECM more options to give you a little more oomph. Neither has any impact on an engine's longevity as long as there's no ping. Allowing the ping to go on for an extended amount of time can cost you a cylinder head or two.
And for those of us with the ECU flash ( stage 1 or 2 ) ---- What say you?????
The compression ratio of any internal combustion engine is the determining factor in the octane requirement...Higher compression engines equal higher performance, thus require higher octane fuel to prevent pre ignition. Thanks to ECM engine management systems they can retard the ignition timing to prevent internal damage...When the timing is retarded so is the horse power...larryd
