Where's my DESS module - 2014 Spyder RT-LTD
PeterFrostad
I have a solid DESS error and before spending the cash on BUDS and the Megatech license, I'd like to at least clean the connections associated with the key sensor antenna and the DESS module but I don't know where those connections are. For example, where is the DESS module on my 2014 Spyder RT-LTD?
Several months ago I cleaned the DESS module connector and applied some Stabilant 22a. Appears to have solved the problem. Haven't had any DESS problems since then.
Hi @PeterFrostad,
What year is your Spyder?
What model is it?
What is Stabilant 22a?
I am glad that you haven't had the DESS problems since.
Deanna
It may have helped, it may have not. I had it come and go several times. Module was replaced, then I replaced the antenna per the bulletin on my 2014 RT.
Looking for someone in the Michigan, Indiana, Ohio area who can disable the DESS on my 2014 Can-Am Spyder RT Limited SE6 - anyone?
