Installed a blindside radar thing. Cheapest one (Weuaste brand) on the market (Amazon) at $58, but it uses the old 24GHz frequency instead of 79GHz.
Now I can tell if a pedestrian sneaks up on me 😆
ResizedImage_2026-07-17_15-10-10_1.jpg 🫪 ResizedImage_2026-07-17_15-09-43_1.jpg
New EBC Rotors and Pads (FA630V) on the front.
OEM Pads/Rotors at just under 10k miles:
- Pads: 1 mm
- Rotors: Warped like a Dime Store Potato Chip.
Hope these perform a bit better for a bit longer than stock...
Am a big believer in benefits of floating Rotors, but MTV's are a tad pricey.
Ikon Shocks on order. Installed BR Ultra bar just after purchase. Front end should be pretty well dialed in.
View attachment 255904 🫪 View attachment 255905
What did you wire it to for the 12v power?
Did you run the display unit wiring in through where the mirrors mount? Where did you run the wiring for the sensor?
Does it actually work?
12v: stock gps power connector
Indicator wiring: goes through the mirror housing. Pop the mirror's cover off and there's a conveniently large hole for you to stick 2 small fingers into to fish things out (and panic when you think your fingers are stuck) 😆
Sensor wiring: ran it up the left beneath the side luggage, past the side luggage compartment release cable, up through the hole where the rear passenger seat heater connection goes (as well as many other cables), fished through a hole or two to reach the center frame channel where all the other cables run, fished up to the front, then just random zigs and zags through the "engine compartment" to reach them mirror holes. There is only one connector (power) for the whole sensor system so it was pretty time consuming to run the whole indicators up to the front...
ResizedImage_2026-07-17_19-48-25_2.jpg 🫪 ResizedImage_2026-07-17_19-48-24_1.jpg
Does it work?: it detected me at a fast walking pace, so there's no reason it wouldn't detect a moving vehicle, I guess. Haven't tested it out in the wild yet. It supposedly has a 100ft range.
Thanks. I appreciate that. You’ve done a neat job that looks very professional.
Getting fingers stuck is something I’m very good at when it comes to trying to hook wires out of tight spaces after being too lazy to take the Tupperware off. I’m also good at dropping small items down in places you never can reach them.
Please let me know how it works in the wild, I’m eager to know. I’ve ordered one so I’d like to know your experience.
