martiniman
Anybody else have this issue, and if so, was a fix available.
Right side (as sitting on bike) works as advertised and looks great.
Left side used to work as advertised.
Now left side is dimmer and rapidly flashes. When I hit the left turn signal it does flash but with no amber. It does not look like the right side when flashing. I’ve disconnected and inspected the splitter, the module and the OEM connector. I also disconnected, inspected, and reconnected the yellow wire that connects to the left side mirror. Everything looked okay. I still have the same issue,
My regular lights on the left side work fine. All I can guess is module issue? Any ideas?
Sadly, at this point, it is worthless. Waste of $150 or whatever it was. I hope Tricled will have a fix (this is my second note to them) but if not, I’ll remove. Any hints on how to remove the glued on LED’s? Heat gun?
