Its not aluminum. Its cast iron and its the same casting as the prior sprocket, just machined differently to accept the spacer behind it. Metallurgy has not changed.
According to Shawn Smoak an experienced Spyder tech and long time youtuber, he states the only one to use is Loctite 609 in the US.
 …….and BRP engineers have been known to slip up in the past, on the odd occasion or two :thumbup:.They sometimes confuse “activity” with real “progress”.
 …….and BRP engineers have been known to slip up in the past, on the odd occasion or two :thumbup:.They sometimes confuse “activity” with real “progress”. :thumbup:
 :thumbup:……and a “Service Manager” doesn’t know this, James?:yikes:
It’s a real worry. It would be ok to say “sorry, I really don’t know”, but to just make something up hints at a larger, underlying issue at that dealership. :thumbup:
I saw in his recent video, that using Loctite 609 only requires 10 minutes to set.
Thats the fixture time cure time is 24hrs.
609 10 minute fixture time 24 hour cure time 2290psi shear strength.
603 10minute fixture time 72 hour cure time 3260psi shear strength.
648 3minute fixture time 24 hour cure time 3900psi shear strength.
So we're glueing together a smaller surface area of splines because we're adding a washer (that no one knows what for) to an unchanged, metallurgy wise, sprocket in an effort to prevent an unknown number of failures 7 years after the fact and after a notification time of 7 months still can't say when the part will be available even though some have been fitted and are out the door and the only official information we can gather is from stealers that are clueless and a tech that makes money from Youtube posts that refuses to answer questions because BRP has scolded him for talking out of class .
:banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead::banghead:
FFS this is retarded!!!!!!!!!!!!!!
Here is a link to the TDS on the Loctite 609. https://tds.henkel.com/tds5/Studio/ShowPDF/?pid=609&format=MTR&subformat=REAC&language=EN&plant=WERCS&authorization=2
Here is the 648 https://tds.henkel.com/tds5/Studio/ShowPDF/?pid=648%20-%20NEW&format=MTR&subformat=REAC&language=EN&plant=WERCS&authorization=2
some have used Locktite 660- any info pos or neg??
We've been using 648 for years at the advice of a BRP Spyder tech. Reading the specs of both it seems like 648 is a better match than the 609. Not sure why they went with 609.....
Lamont, how long does it take to cure after using to fit a sprocket?
How about asking BRP engineers? I presume you have inside contacts that run a lot deeper than what we ordinary mortals have, right?
When I was in the quality assurance field I had a motto, QA QA QA; the Questioning Approach of Quality Assurance leads to the Quintessential Answer.
If you can't even get the pulley, the type of Loctite is not something I am worried about right now.
I am not gonna let the dealership work on my scooter, even if it is free warranty work.
It would still cost about $100 worth of gas and two trips to Gville, which would ruin 2 days for me.
They talking about 6 months to a year just to get the pulley. I am looking for some other source.
Any ideas?
Soooo……once this new pulley is installed onto the splined shaft using whatever Loctite used, if ya gotta remove the pulley at any future date……whats the procedure?I don't have the line of communication I once had. I'm just an ordinary mortal too
