TicketBait
RT-S PE#0412
Had trailer all packed up for Spyderfest trip.
Went to check the tire pressure in the trailer
tires and they were both low, 17lbs, should be 35:yikes:
So I have a portable compressor I put air in and when I went
to check one of them the tire valve stem little pin was
stuck in the inverted open position, so the air would not
stop till I put the cap back on. Then no air is escaping
I filled it back up, and put cap back on. Is it ok to pull
trailer empty to a tire repair shop 1 mile away, or do
I need to remove tire and take to them?
Also if I have to take off the tire, where do I put the
jack under the trailer?
Remember you are speaking to someone with very limited
repair knowledge.
And on another note, today I check my oil and I have too much in it,
so I go and buy a siphoning extractor, and extracted 160z, only to
learn I needed to add 8 oz of new oil back. That was a good thread I read.
Then in my search for finding an answer for this question, I read allot of
posts about repacking/ servicing trailer bearings at 12k miles, although
Scotty recomends each year. I probably have 10k miles on my trailer
over the last 3 years, I hope they serviced it last year at the dealership. :dontknow::gaah:
repair knowledge.
