wyliec
I originally put in 9 oz. (front tires) and 13 oz. (rear) in 2009. In Jul. of last year I added more ride-on so that there is now 13 oz (fronts) and 18 oz. (rear). After adding ride-on I noticed a vibration from @55-62 mph whether it was in gears 3, 4, or 5. I'm not so sure it was the added ride-on b/c a few months before I had the belt tension reduced at the dealer.
It's possible that I just didn't notice the vibration after the belt adjustment b/c it's not that bad. Has anyone else found that they may have added just a bit to much ride-on and developed a small vibration.
I contacted Capt. Jim and he said the best way to determine if it is the belt that is causing a vibration is to take it up to between 55-62 mph (my vibration area) and hold it steady at one speed; if it is the belt the vibration should clear up.
Capt. Jim I hope I quoted you correctly. The problem is right now the bike is parked for the winter and I won't be getting it out for at least 2 months. I'm asking about the ride-on b/c although I would like to purchase the belt tensioner now and install while the spyder is parked for the winter, I'm hoping someone can tell me what may happen with a few oz. too much of ride-on.
