How crucial is rear tire balancing?? If the tire's a good quality tire (like the Vredestein's are) without any red or yellow paint dots on it, chances are it's pretty well made with 'good balance characteristics' in mind anyway, so doing an more/extra balancing is probably not all that crucial at all.
BUT, just to be sure, while you've got the wheel off the rear & once the tire is off the rim,
carefully check the rim's outer bead edges and all the bits that are usually covered by the tire. There just
might be marks, indents, or embossed dots on the rim itself to show its heaviest spot (if those're gonna be there, they are usually vaguely opposite the valve stem hole...
) or the point of maximum radial run-out; and
IF you've got anything like that on the rim, then it'll probably be a good idea to find a local motorcycle tire fitter or someone who
CAN do a balance, even if it's just a rudimentary thing! Or you might want to invest in some balance beads or goop etc (not really my preferred option! :sour
:dontknow:
Seriously tho, with a single rear wheel that's held by a thru axle and the swingarm on each side & a good quality tire, there's a better than '
just good' chance that you won't need any additional balancing of the wheel assembly, especially if your previous rim/tire assy didn't have any great imbalance problems! And even if the rim
DID have a bunch of weights on it with the OE Kenda fitted, it's
most likely that those balance weights were necessary because of the Kenda tire - altho there have been a
few instances of BRP rims being dodgy too... just no-where near as many as there's been of dodgy Kendas!! :banghead:
However, if you're capable of taking the wheel off & the rim & tire have no special balance marks or dots on them, then there's a better'n very good chance you'll actually be
more than capable of working out if you need anything more in the way of a suitable balance yourself anyway, even if it is a bit rudimentary! You'll only need the axle tube to spin the wheel on; a few blocks of wood or bricks to stack up high enough, or axle stands to hold the axle either side of the bearings/sprocket/disc etc in order to spin the wheel on while it's held up in it's mounted position - if you spin it a few times or more and it never settles in exactly the same spot/orientation, then it's going to be telling you it's pretty reasonably balanced anyway! (If it won't spin freely like that, check & replace the axle bearings! :lecturef_smilie: ) And if you also push something solid up
close to but not quite touching the
edge of the tire tread while you're spinning the wheel, then keep an eye out for any variations in the gap between that 'something' and the edge of the tread, no or minimal change in the gap is a strong indication that there's little if any run-out too! :thumbup: So if the wheel stops spinning in random spots every time & there's no great gap variation while it's spinning, then given the single rear wheel & the way that wheel is held by the swing arm teamed with the lack of balance dots/indicators on the quality tire &/or the rim, there's a pretty good likelihood that your wheel is quite well balanced and you won't ever notice or need any more balancing than that!
hyea:
Only if you've gone for the cheapest or least known brand of tire you can find &/or one that's not made by a recognised/reputable tire manufacturer and it has no balance or run-out dots on it, all bets are off & you're on your own! :yikes: All the above only applies to a quality tire made by a recognised & reputable manufacturer! :cheers:
