interference from led fog lights
fzflyer, Plus as you check though all these suggestions, you're likely to be removing and resetting some grounds, and insuring that everything is tightened properly. If your LED's were from Lamonster, you might want to check with him about the fix that Ex-Rocket mentioned.
Your fog lights should have a push button switch mounted where you can turn them on or off. I know on my 2017 F3 Limited I do. Thats how I found out that the fog lights were causing the static on the radio by turning them on & off. When I turned the fog lights on the static was there.
Now to add something else to this-------
Yesterday after fueling up, I got a DESS fault and the :spyder2: wouldn't start. Yes, I had this problem years ago and changed the DESS module. BUT, I had my fogs and additional driving lights on. Driving lights are 10watt LEDs ( each, and HIGH mounted) but when I shut both off and pulled the key for a few seconds, the :spyder2: started right up and no other faults for the day.
So, could these LED's cause interference with the DESS signal?????
Lew L
No need to do that. Just pull out the headlight relay in the fuse box.I’m currently in the process of learning how to remove the body panels so I can physically unhook headlights and DRL/fog lights to isolate and diagnose.
Lew L
Yes. They can. I had the same problem with a cheap headlight upgrade kit I installed. I'm not saying your setup is cheap. Only that the power conversion module can emit RF/EMF that will drive the ECU crazy. If the ECU cannot interpret the signals it is receiving due to interference. It may just refuse to start the vehicle.
In my case. I purchased a better kit and my problems went away.
Check any USB power adapters you may have. Just like LEDs, some of them can cause static in the radio.
If you haven't gotten one yet, you would be well advised to buy a service manual. They're about $30 from www.canammanuals.com in PDF format. There are several sites all connected to this one and selling the same manuals.
There are a few items on the Spyder, such as the headlights, that are served by a load shedding relay. It activates only when the engine is running, and for about 20 seconds after turning off the ignition.
Broadcasting station, or transmission tower? Big difference! The radio on my 2014 can get iffy if more that about 35 to 50 miles from a tower.Maybe, I am expecting too much from the radio on this bike?? Makes me question BRP/Can-am if they, along with their suppliers, cannot put together an audio system that reaches essentially 10 miles from broadcasting station. Hmmm…
