I can't find anything about front shock preload in the F3 manual. Can you help me out?
There has to be information in the manual about Front Shock Spring Pre-Load adjustment. But I don't have the manual so this is the best I can do.
Here is a picture of an OEM F3 Shock (Fox). As you can see it is currently set at a Mid-Load adjustment.
I am told that BRP does NOT supply you with a Spanner Wrench for these shocks. Shame on Them! So here is a link to an eBay listing which you may need. I am not promoting this particular spanner wrench but I may ask for a commission if his sales increase enough! You do need 2 spanners to do this correctly.
2x Motorcycle Shock Absorber Preload Spanner Wrench Tool For Honda Suzuki ATV
You will notice 2 Locking Rings on each shock at the bottom of the spring. The Upper Ring (Blue Arrow) makes the adjustment and the Lower Ring (Red Arrow) serves to lock the assembly once the adjustment is made to prevent any movement.
Before you start it is a good idea to measure the length of each front shock spring (from flat spot on top to flat spot on the bottom). This will tell you if they are currently adjusted equally. This is VERY important. If no one has messed with them from the factory you should find identical spring length on both sides. If not, the first thing you need to do is adjust one side or the other so that both spring lengths match.
To Raise or Lower Spring Pre-Load you need to first loosen the Lower Locking Ring (Red Arrow). Do this by holding the Upper Ring (Blue Arrow) stationary with one Spanner Wrench. And turning the Lower Ring (Red Arrow) clockwise (looking down from the top) with the other Spanner Wrench. This separates the 2 rings allowing you to make the Pre-Load adjustment with the Upper Ring (Blue Arrow)
Increasing Shock Spring Pre-Load. Turn the Upper Ring (Blue Arrow) Counter Clockwise (looking down from the top).
Decreasing Shock Spring Pre-Load. Turn the Upper Ring (Blue Arrow) Clockwise. (looking down from the top).
Once you get the Upper Ring where you want it, you MUST lock the rings together (as they were before you started this process). Do this by turning the Lower Ring Counter Clockwise until it stops up against the upper locking ring. Then cinch the 2 rings together by holding the Upper Ring stationary with one spanner wrench while turning the Lower Ring Counter Clockwise until it is tight against the upper ring using the other spanner. (Opposite of what you did to get the 2 rings separated).
VERY IMPORTANT! You MUST count the turns you have made on the Upper Ring. I highly recommend marking the upper ring (if it is not already) in some permanent way so that you KNOW how many full turns you have made. Making Full turns is the best way to keep track.
Then you MUST make this identical adjustment to the other front shock. And you MUST go UP on both sides or Down on both sides the exact same number of turns. I have seen front shocks that have 1/2" or more difference in Spring Pre-Load adjustment. Talk about something that will mess with your steering, tracking and handling! :yikes:
This is a very easy process and can make a world of difference (improvement) in how your Spyder handles. You might want to experiment a little at a time. I recommend 2 full turns as with 1 full turn, you may not be able to tell any difference at all.
For those of you who LOVE videos. Here is one that should give you a visual of my explanation above. This is for a car but the process is identical.
https://www.youtube.com/watch?v=Me2mdTTOZ6U
Hope this helps! :thumbup:
