terminal3k
Thanks a lot for all your help. I will give that Motul a try. Is clutch slippage when it doesn't change gear smoothly? Because I have had that a couple times before on the BRP oil.
It looks like the half round metal is a broken piece of metal... The one end is sharp and jagged
The half round wire looks like a wire that raps around the needle cage. The wire is used to hold the needle bearings in the cage during assembly of the transmission, when putting in the pinion gear and when finished the half round wire is thrown away and in your case it was thrown. I have seen this wire before on friends 2011 RT when he changed his oil in my garage and his RT had over 20,000 miles on it. Don't worry be happy and ride without worry. That's IMHO.
Mike
