funon3
While out riding today and checking the instrument cluster I noticed that the digital tach and analog tach were showing different RPM's. When I stopped the digital tach was showing 1300-1400 RPM's at idle which, I believe, is about normal for the 998 engine. The analog tach was showing around 700-800 RPM's which leads me to believe that the problem is with the analog tach. I usually use the analog tach when shifting as it is easier for me to see so I think I was probably shifting at much higher RPM's than I normally do. Has anyone seen this type of problem? Any help or ideas would be appreciated. :hun::gaah:
