trong
Hi All,
Vehicle: 2013 RT Limited SE5 with 1452 miles. Bought it last year with 45 miles on it, the Spyder was in brand new condition with bad tires for sitting flat too long.
Soon after I got it, I replaced all 3 tires, also the battery replaced with a Yuasa same model that was in the Spyder, oil and filters were replaced at 400 miles. We put about 1400 miles, trouble free, on it in since last year including at least one ride per week since weather got nice last month. Battery is kept charged during winter months, start up and ride occasionally weather permitting. No major modifications both electrical and mechanical, just a stop light flasher module installed on left stop light last september.
Problem: We took it out for a ride like we normally do on weekends, destination unknown, with stop and go traffic highway. Everything was working fine with no symptom or error. Stop at a traffic light, about 20 miles from home, the Spyder downshifts to first gear fine. Light turns green I take off then could not shift to 2nd gear, try few time then pull over about 800 feet away. Turned off then turned on, the Spyder did not shift itself to Neutral like it normally does. With engine running, I could not shift out of 1st gear to either Neutral or Reverse. Called tow truck, they said they will be there in about an hour. While waiting I disconnected the battery and wait a few minuted thinking that could reset the TCU, that did not help. Checked the oil and it a little more than half way between empty and full marks.
Got the Spyder, on flat bed, home and I google the shifting problem with the SE5, quite a few suggests to check the shifting linkage, and the paddle shifting switch, Guess what, both were fine. I use a 13mm wrench to manually shift while engine is off, I could go back and forth between R, N, and 1st. The Spyder actually goes backward when I put it in R. I put it back in 1st manually then drive it in the garage for now.
At this point I think either the Hydraulic Shifting Actuator or the Transmission Control Unit causes the issue.
Anybody with the similar issue and what was the culprit?
Thanks in Advance and cheers.
