Spyderman62
The Grip Puppies assist in softening and enlarging the grips for comfort. All were "in stock" from other bike mods. I'll use these until I decide what to do for heated grips. They are, however, a "bear" to install even using soap and water.
The nest time you want to install a set of Grip Puppies, try using compressed air. Simply put the nozzle in the open end while pushing the other end onto the existing grip. Then squeeze the remainder of the grip around the nozzle, and squeeze trigger to allow air to flow - lots of air to flow. The air blast will swell the grip puppy and allow you to push it onto the existing grip. Hope this helps.
