SpyderWolf
XPS
X‑tra Protection
(Part Synthetic)? :dontknow:
X-tra Profit Sucking.
XPS
X‑tra Protection
X-tra Profit Sucking.:roflblack:
When I looked this up on the BRP Website, it was not listed as recommended for the Spyder. I am guessing it is a wider viscosity range.
I fail to understand why so many have their feathers fluffed over what oil to use. The Spyder engine is no different than any other motorcycle engine and just about all bike engines made today use wet clutches. ANY motorcycle oil that is labeled "safe for wet clutch applications" is perfectly acceptable for use in any bike, the Spyder included. 5W-40 or 10W-40 are both OK to use. BRP had been using Castrol oil for years. When they got a "better deal" from another mfg they switched suppliers. The Castrol oil was green in color, the new supplier's oil was brown. They may have switched back to Castrol oil or perhaps to yet another brand. They buy from whoever gives them the lowest price. The almighty buck is more important to BRP than the quality of the oil. There is one oil that I would never use in any vehicle.....it's BRP's XPS oil !! They don't put the rating designations on the container because they switch suppliers so often that they don't know what the current rating are !!
On another note.....synthetic oil has an expiration date. It might not be wise to use oil that has been sitting at a low volume dealer for years. While it might have the designations you want, it probably will not perform as well as the latest batch of oils and might even be harmful to your engine..
Yeah nitrogen in the tires.
I have read more than once, that changing your oil brand is not a good idea from oil change to oil change. As one brand has additives that another may not, and they can create a reduction in that oil change life cycle as the new oil is fighting the additives of the old. Evidently this can simply mean a 3500 mile oil change simply needs to become a 1750 mile oil change and from there you are good to go until you change brands again.
I just got back from my dealers Christmas party. His BRP oil arrives on Castrol pallets.
BRP oil is just like Harley brand oil. they get who ever bids lowest to make it for them.
but Harley does say that they have a formula or spec that the supplier has to meet in order to mfg the oil for them. i.e. the oil is the same standards just mfg by different vendors for Harley. (that is what they say). at least they give you the weight of the oil on the bottle along with full synth or standard oil option.
anyway this is where i get off the bus for this thread :banghead:
I am sticking with Motul 300V 4T.
Ha!
When I saw this photo, Lou, I thought that was you leaning into the turn and that you had replaced your RoadGlide!!! :yikes: :joke:
Not me, but I did replace my RoadGlide......with a newer RoadGlide.....![]()
See! There you go! Asprin goes back in the cupboard and life is good!hyea:
hey weren't you getting off this bus before me :spyder:
The bus I was referring to was the circular issue of warranty concerns, I love the oil bus! :clap:
I don't have any warranty concerns. I let the dealer put the so called BRP XPS in. I don't think about who actually produces it, what the weight is or any additives. And, I know it would be cheaper to change my own oil. But, then I would have to be concerned about all the info presented in this thread and then I would have to worry if I had an old batch, a new batch, an in between batch with this additive or that additive.
I just love to ryde and not have to worry. Isn't life great.
Ron, you made me say all this.
