Wildrice
Is there an info location as to which size metric screws are needed per mounting location? Some of mine are longer--mostly m4 or m5, the sheet metal screws holding the headlamp outer panel were way to loose/stripped--replaced with larger screws. One of the lower windshield mount screw was cross threaded & torque head stripped & easy out failed to remove :-(
I gots to stop working on this F3's at night in dim lighting:banghead:
