KJWEB
this is very interesting. Sometimes when I take those panels off and put them back on they push the grommets thru. That has happened twice now. Once the rubber fell all the way thru and once I lost it in the black hole of the inside of the Spyder. Interested to see what happens.
Put a zip tie around the grommet and you will not lose one if it happens to push through. Also, each time you take off panels, spray a little silicone spray on the rubber grommets and it will keep them from cracking and tearing.
