Hey Magic Man I know that the CANBUS is a very finiky creature and to just add lights to your spyder as you desire will cause the CANBUS to have a hissy fit. Obviously the "black box" of the triple play (which by the way I do have installed) looks after this CANBUS issue. With this in mind is it possible to tap into the outputs of the triple play black box to add additional lighting. For example if I wanted to replace the licence plate light with a brake light can I just tap into the installed NMN middle brake light (i.e. black box outputs for it) or will adding the additional load to the NMN triple play black box cause problems. What about taping into the triple play outputs to control a relay that sends power to additional lights ?
Thanks in advance.
Thanks in advance.
