Joel The Biker
I upgraded the battery on my spyder to a lithium battery. It is $230 but is extremely lightweight (I thought the box was empty) and is about 1/3 the size. It last 4x longer than lead acid batteries also. If you buy one, it comes with foam spacers. Use 2 thick spacers on the bottom and 1 thick spacer on the top of the battery. Also, keep the RED plastic cover for the + side and cut the end off so you can keep it on the battery and protect from shorts. You can cut the top foam to fit the spyder battery clamp also. DO NOT install the battery with no foam on top of the battery. The battery clamp will short it out! If you don't feel comfortable, please have an experienced person do it. This battery is awesome!
